okipol
May 31, 2021Aspirant
1Gigabit capable Netgear NAS + Access Point
Hello, I am a proud owner of Netgear WNR3500Lv2. I have custom tomato running on it (yes deprecated unfortunately). I have an ISP rated 300 Mbit but on directly conected it could go up to 700 Mbi...
Jun 04, 2021Guru - Experienced User
okipol wrote:
I am searching for a router that will be running in AP mode and having NAS 3TB or more.
FYI, you didn't post this in the right forum. ReadyNAS is Netgear's NAS product line - which doesn't include their routers that support USB drives (sometimes called a "NAS" feature).
Netgear routers do drop some features when running in AP mode. It is possible that attached USB drives might be one of them - not sure, since it's not a mode I use. One workaround is to double-route - which works ok, though port forwarding, etc becomes a bit more complicated. Anyway, you might want to follow up in the router forum area.
okipol wrote:
I want to run AP + NAS and have Gigabit speed on cable. I preordered a Netgear R6400 Router Wifi AC1750 USB 3.0
You won't get gigabit file transfer speeds (~100 MB/s) using the R6400 NAS feature. Based on this review, it will be around 20-30 MB/s: https://www.pcworld.com/article/2960533/netgear-r6400-review-netgear-s-latest-mid-range-router-is-a-solid-value.html
The R6400 is an older mid-range model, you would get faster WiFi speeds with something higher end. That would be more expensive of course. No idea on whether you'd also get faster NAS speeds.
okipol
Jun 09, 2021Aspirant
Hi,
Yeah rewised I am not using AP mode (oh yeah).
Having that in mind I am getting Internet speeds @ Down 400 Mbit / Up 900 Mbit. The NAS is around 20 MB/s. That is a really nice upgrade from my last Netgear WNR3500v2. Also I pay for a symetrics 300Mbit :P. I will be thinking about using some custom Firmware for it ;). I really liked the advanced tomato.
