LWReid's avatar
LWReid
2 dead disks in RNDP6000v2
Hi, I had disk 3 (out of 6) with bad sectors reccomending replacement so I hot plug replaced it but the NAS did not see new disk insert. I left it overnight thinking it may be formatting or somethi...
  • StephenB's avatar
    Jul 30, 2018
    Cloning disk 6 or the original disk 3 might help get you through this.   Note that this usually results in some filesystem corruption (because the unreadable sectors can't be cloned and can't be recovered either).  So there could be some data loss.  You need a cloning tool that does block by block copying.  You'd power down the NAS, do the clone, and insert the cloned disk with the NAS powered down.
    If disk 3 is still readable, you could also try powering down the NAS, reinserting the original disk 3, and then powering up again.
    Either way, I suggest using the boot menu option to skip the file system/volume check.  If your files are available, then do a full backup of the data files on the NAS.
    Netgear also offers a data recovery service that you might consider: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
ProSupport for Business
