pixel81
Feb 28, 2012Guide
3TB (GPT) external disk support via USB3.0 on ARM Duo/NV+ v2
I'd like to see GPT (GUID Partition Table) support for 3TB and larger external drives connected to the ARM ReadyNAS products (Duo V2 / NV+ V2) via the USB3.0 ports. Thanks
PapaBear1
Aug 29, 2012Apprentice
I have a Sans Digital TR5M+B set up as a JBOD box. Now this version uses an eSATA cable that must be connected to a desktop add in card. I used it for a long time for backups before I was able to get a second NAS so I could do an NAS to NAS backup via rsync, the fastest and easiest way to do a backup. The ARM based Duo v2/NV+ v2 supports rsync if running RAIDiator 5.3.5.
