rtrogemann
Jul 23, 2016Aspirant
4TB+4TB+2TB+2TB= 3,6TB????
Hallo habe vier Festplatten eingebaut, 2x4TB und 2x2TB und bekomme als freien Speicher 3,63TB genannt? Kann das sein??? Liegt das an RAID6? Was muss ich ändern? I have two 4TB Harddisks and two 2...
Hopchen
Jul 23, 2016Prodigy
Are you sing X-RAID or FLEX-RAID?
In X-RAID configuration, the above should give a volume size of ~7.x TB.
Can you screenshot the volumes page for us? "System" --> "Volumes".
- rtrogemannJul 23, 2016Aspirant
- JennCJul 23, 2016NETGEAR Employee Retired
Hello rtrogemann,
Although it is on XRAID, it is currently using RAID6. Did you add 2 disks to the existing volume at the same time? Do you have full backup of the files? If not and you can still access files, please back up.
No, I don't have backups - but it's ok. And yes, I did exchange 2 volumes mostly at the same time. What do I have to do to get the full capacity?
