rtrogemann
Jul 23, 2016Aspirant
4TB+4TB+2TB+2TB= 3,6TB????
Hallo habe vier Festplatten eingebaut, 2x4TB und 2x2TB und bekomme als freien Speicher 3,63TB genannt? Kann das sein??? Liegt das an RAID6? Was muss ich ändern? I have two 4TB Harddisks and two 2...
Retired_Member
Jul 23, 2016X-RAID doesn't create a RAID6 on four HDDs, regardless of how many HDDs you replace at once. X-RAID create RAID6 volumes during a Factory Default if 6 HDDs or more in a chassis with 7 bays or more. X-RAID reshapes RAID5 arrays to RAID6 during horizontal expansion starting at the 7th member.
I can't see the pics as they're not approved (which is annoying btw), but maybe the user disabled X-RAID, created the RAID6 volume, and re-enabled X-RAID.
Anyway, the only one to get back to a RAID5 is to destroy the volume and recreate one.
