Wildtexaschef
Dec 01, 2014Aspirant
6.2.0 has no manual to download
There is no manual for the new firmware 6.2.0 release.
A manual is needed to explain in better detail the new features, how to use them and what they are.
I have several question in regards to 6.2.0
1. What is "scrub", how does it work? What does it do? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
2. What is balance? how does it work? What does it do? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
3. I do know what defrag is, but how does netgear implement it? how does it work? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
4. Disk test, how does it work? What does it do? About how long does it take? Is the time it takes to complete based on the volume size, or on the actual amount of data on the volume?
5. In regard to the auto power on and off. If the NAS is busy doing a scrub, balance, defrag, or disk test. Will it turn off or will it complete the task then turn off? Same goes if it's busy with a backup or replicate. Will it turn off in the middle of those tasks as well? Or will it completed them first before turning off.
6. If the unit is powered off automatically, and there is a scheduled task to start at a time that the unit is powered off, will it automatically turn on and start the task? Or must we schedule the unit to power on before the task is scheduled to start?
Those are just some of my questions I have that can't be answered from reading the manual to 6.1 firmware, and you have not released the manual for 6.2.0
- btaroliProdigy
mdgm wrote: That checkbox might be referring to snapshot protection. Can you post a screenshot?
Sure
- mdgm-ntgrNETGEAR Employee RetiredThat's under the snapshots tab, so I think it must be referring to snapshot protection.
You may wish to use snapshot protection just for some users. - btaroliProdigySo you can't COW for homedirs?? Weird. Seems piecemeal to me...
