jboroden
May 16, 2016Aspirant
Adding a drive to ReadyNAS 204 #26877295
I have a readyNAS 204 with 2 drives set as raid1, can I add a 3rd drive and use it as a separate drive?
anna_arun
May 16, 2016NETGEAR Expert
If you dont want the new drive in the same volume , switch off X-RAID and add the drive . You can create a new volume and use the drive .
BrianL2
May 16, 2016NETGEAR Employee Retired
Hi jboroden,
Welcome to the community!
From X-RAID2 it'll be on Flex-RAID. Here are some NETGEAR articles that'll help.
Changing Volumes from X-RAID2 to Flex-RAID
Kind regards,
BrianL
NETGEAR Community Team
