jboroden
May 16, 2016Aspirant
Adding a drive to ReadyNAS 204 #26877295
I have a readyNAS 204 with 2 drives set as raid1, can I add a 3rd drive and use it as a separate drive?
anna_arun
May 16, 2016NETGEAR Expert
If you dont want the new drive in the same volume , switch off X-RAID and add the drive . You can create a new volume and use the drive .
BrianL2
May 19, 2016NETGEAR Employee Retired
Hi jboroden,
Are you still having issues adding a new drive in your ReadyNAS system?
Kind regards,
BrianL
NETGEAR Community Team
