art305
Jan 12, 2022Aspirant
Adding disks to a existing raid 0 with out re setting NV+ nas to default
Hi I wish to add 2x2TB drives to my Netgear ReadyNAS NV+ 2x2TB drives Raid 0. Can I just delete the volume (loss of all data the data is backed up). Insert the 2x2TB into the NV+. ,Restart the NV+...
- Jan 13, 2022
It sounds like you already are using flexraid, and have a RAID-0 volume. If so, you can avoid the RAIDar setup.
The process you want is outlined on page 21-22 here: https://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf
You will need to reconfigure the volume (recreate shares, etc).
One alternative option is to create a second RAID-0 volume (D in your case) and shift some shares over to it. In most cases there is no operational impact (normal SMB access just gives you the share list). You do need to keep an eye on free space, and make sure you have reasonable space on both volumes. But in practice I haven't found that to be a huge problem.
The alternative would be faster to set up, and would be non-destructive.
Jan 13, 2022Guru - Experienced User
- art305Jan 13, 2022Aspirant
Thanks big help.
Disks added and working I chose to proceed as the 1st part of you reply.
The process did delete the shares so I imported a config back up I had created.
Thanks again
Arthur
