mrearthpig
Mar 29, 2016Aspirant
Adding drives without redundancy
Howdy! I have a RN102 which I use as a media server, running Plex. It's been working great up until I ran out of drive space recently. The unit currently has a single 2TB drive in it. I have ...
mrearthpig
Hi AlexPe!
I have a 2TB drive which currently has all my media on it.
I added a 3TB drive and wanted to use the full 3TB as additional storage.
The RN102 configured both drives as RAID 1 automatically.
I don't need them to be set up as a RAID and want them to be configured as JBOD, so that I have 5TB of storage.
Can I reconfigure this without having to copy everything off of the drives first?
mdgm-ntgr
Mar 29, 2016NETGEAR Employee Retired
You would need to backup your data (you should do this regularly anyway if your data is important), disable X-RAID, destroy the volume (deletes all data), then create the volumes you want. I would suggest calling the first volume 'data' (no quotes). Then you could put the data back on.
