johnkiss
Aug 01, 2019Follower
Adding Seagate 10tb drives to a RN212
while the Seagate 10Tb IronWolf ST10000VN0004 is shown as compatible in the Netgear list, the drive lacks the middle screw hole and therefore will not accept the drive carriage without cutting off th...
Sandshark
Aug 01, 2019Sensei
You can secure it well enough using two screws to mount via the holes in the bottom, with or without the (modified) plastic insert. I frankly don't know why Netgear went to the plastic insert. It's not like people swap out their drives on a regular basis.
