johnkiss
Aug 01, 2019Follower
Adding Seagate 10tb drives to a RN212
while the Seagate 10Tb IronWolf ST10000VN0004 is shown as compatible in the Netgear list, the drive lacks the middle screw hole and therefore will not accept the drive carriage without cutting off th...
Aug 02, 2019Guru - Experienced User
johnkiss wrote:
I'd really like to see "physical compatibility" addressed on the list as well as electronic compatibility, but contacting Netgear re something like this is not easy.
FWIW, Netgear has already addressed it. Newer trays have been modified.
As Sandshark says, you remove the plastic insert and use the screws that came with your NAS to attach the disks to the bottom of the tray.
There's more details (including how to remove the insert) on pages 163ff in the hardware manual: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
