be9000's avatar
be9000
After changing disks X-RAID only shows status "spares" but not "raid"
Hi,
i replaced on 3 TB disk with a 6 TB disk and let it resync. When finished I replaced the other 3 TB disk with a 6 TB disk.
The Web-GUI says it is finished but the icons are still "green" which means "spare" and not blue which means Raid. There is no error message in the GUI-events log.
I activated SSH and investigated the MD-Raid status  via /proc/mdstat:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid1 sdb3[3] sda3[2]
      5855672800 blocks super 1.2 [2/2] [UU]
md1 : active raid1 sda2[0] sdb2[1]
      523264 blocks super 1.2 [2/2] [UU]
md0 : active raid1 sdb1[3] sda1[4]
      4190208 blocks super 1.2 [3/2] [UU_]
Why does it want to have 3 disks instead of 2 in md0 and shows a degraded state? UU_
Further info on md0:
# mdadm -D /dev/md0
/dev/md0:
           Version : 1.2
     Creation Time : Sun May  1 19:48:46 2016
        Raid Level : raid1
        Array Size : 4190208 (4.00 GiB 4.29 GB)
     Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
      Raid Devices : 3
     Total Devices : 2
       Persistence : Superblock is persistent
       Update Time : Tue Feb  2 13:23:29 2021
             State : clean, degraded
    Active Devices : 2
   Working Devices : 2
    Failed Devices : 0
     Spare Devices : 0
Consistency Policy : unknown
              Name : (removed by me)
              UUID : (removed by me)
            Events : 19508967
    Number   Major   Minor   RaidDevice State
       3       8       17        0      active sync   /dev/sdb1
       4       8        1        1      active sync   /dev/sda1
       -       0        0        2      removed
So whats this strange "RaidDevice 2" in state "removed"?
How can I get the fuzzy warm feeling of having a working Raid1 again?
Thanks for any hints
Bernd
  • The "LED" is not normally blue -- I've never seen one blue.  The LED will be yellow when the volume is re-syncing, which is the change I suspect you saw..  Your NAS volume is as it should be, there is no need to do anything.  When a drive is a spare, the part of your drives that is blue is green.
  • md0 is the OS partition, which is a RAID1 (or 10 on larger NAS) with a partition on all drives in the system.  While it showing a removed drive is unusual, at least it you've rebooted the system, it's not your main issue.
    First, verify XRAID is enabled (green bar on the XRAID button on the volumes page),  If you are not in XRAID, expansion isn't automatic.
    If XRAID is enabled and you didn't try rebooting the NAS, try that first.  It has been known to kick off an expansion.
    Your problem is that while you have an md127, which is your data partition and I assume consists of the original 3TB partitions of the drives, it didn't create an md126 from the added 3TB partitions (and likely didn't even create the partitions) and add them to the BTRFS file system.  Please post a similar listing for md127, but don't remove the name.  I have recently seen a similar issue of non-expansion, and a wrong name was a partial clue.  If there is really something you don't want people to know about the name of your volume, then just confirm that the name is the hostid:volumename-0.  For example, mine is 7fc780f2:data-0 for volume data.
    Also post a listing of fdisk -l  /dev/sda  /dev/sdb and btrfs filesystem show.
    • be9000's avatar
      be9000
      Thank you very much for your detailed reply!
      I rebooted (again, already did that; once from the console and once from GUI).
      X-RAID is activated (green Bar).
      Let's see md127:
      /dev/md127:
                 Version : 1.2
              Raid Level : raid1
              Array Size : 5855672800 (5584.40 GiB 5996.21 GB)
           Used Dev Size : 5855672800 (5584.40 GiB 5996.21 GB)
            Raid Devices : 2
           Total Devices : 2
             Update Time : Wed Feb  3 08:19:51 2021
                   State : clean
          Active Devices : 2
         Working Devices : 2
          Failed Devices : 0
           Spare Devices : 0
                    Name : 117ad524:data-0  (local to host 117ad524)
                    UUID : (a UUID)
                  Events : 24229
             3       8       19        0      active sync   /dev/sdb3
             2       8        3        1      active sync   /dev/sda3
      fdisk - /dev/sda /dev/sdb:
      # fdisk -l  /dev/sda  /dev/sdb
      Disk /dev/sda: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors
      Units: sectors of 1 * 512 = 512 bytes
      Sector size (logical/physical): 512 bytes / 4096 bytes
      I/O size (minimum/optimal): 4096 bytes / 4096 bytes
      Disklabel type: gpt
      Disk identifier: (a UUID)
      Device       Start         End     Sectors  Size Type
      /dev/sda1       64     8388671     8388608    4G Linux RAID
      /dev/sda2  8388672     9437247     1048576  512M Linux RAID
      /dev/sda3  9437248 11721045103 11711607856  5.5T Linux RAID
      Disk /dev/sdb: 5.5 TiB, 6001175126016 bytes, 11721045168 sectors
      Disklabel type: gpt
      Disk identifier: (another UUID)
      /dev/sdb1       64     8388671     8388608    4G Linux RAID
      /dev/sdb2  8388672     9437247     1048576  512M Linux RAID
      /dev/sdb3  9437248 11721045103 11711607856  5.5T Linux RAID
      btrfs filesystem show:
      Label: '117ad524:data'  uuid: (and another UUID)
      	Total devices 1 FS bytes used 1.50TiB
      	devid    1 size 5.45TiB used 1.51TiB path /dev/md127
      • StephenB's avatar
        Is mdstat showing you an md126 yet?
ProSupport for Business
