cduggins
Jun 17, 2022Guide
after move cannot connect to NAS 316
after moving I cannot connect to my NAS, but I am able to still see my son's NAS and connect to it in ReadyCloud error message from RAIDar........says network error but I can connect to my sons. I ...
- Jun 21, 2022
I did the OS reset and I'm up.
Thanks for your help.
Jun 17, 2022Guru - Experienced User
cduggins wrote:error message from RAIDar........says network error but I can connect to my sons.
I am running Windows 11
Are you seeing the NAS on the attached device list in your router?
- cdugginsJun 17, 2022Guide
I can see the NAS but it does not accept my login
says not accessible..........need permissions.
- StephenBJun 18, 2022Guru - Experienced User
Try running CMD on the PC. Then enter
net use * /delete /y net use t: \\nas-ip-address\data /user:admin nas-admin-passwordusing the real NAS IP address and and admin password of course. Be careful on the typing - the spaces and the slash directions both matter.
That should mount the data volume of the NAS as drive letter T. Let us know if that works (or if not, what error you get).
- cdugginsJun 18, 2022Guide
I found another list on the router that gives me a IP I am going to try it.
C:\>net user */delete /y net user t: \\nas-ip-192.168.1.110\data/user:admin nas-admin-password
The syntax of this command is:NET USER
[username [password | *] [options]] [/DOMAIN]
username {password | *} /ADD [options] [/DOMAIN]
username [/DELETE] [/DOMAIN]
username [/TIMES:{times | ALL}]
username [/ACTIVE: {YES | NO}]I thought I had all the spaces correct...but must be missing something???
I cannot find a IP for the NAS.........my router only shows the mac address and under IP4 shows unknown
IP6 fe80:eafc:afff:fee6:ed00
