ptoro1
Dec 30, 2020Aspirant
APC 1200 via USB not working
I have a ReadyNAS Pro 4 (4.2.31) connected to an APC XS 1200 via USB with no issues. I moved that USB to this my other ReadyNAS 426 (6.10.4) and I get the following errors (I removed the serial n...
milind2021
May 02, 2021Aspirant
Bump, I really think this needs to be escalated, it is one of the supported models by NUT StephenB JohnCM_S Marc_V
Sandshark
May 02, 2021Sensei
Of course, the version of NUT in the ReadyNAS is not the latest, so that could be a part of the issue. But Netgear has also clearly set up some sort of auto-detection and configuration that's not a part of NUT (and I wish I could turn off). If that's the only part that's not working, perhaps you could manually create a configuration file, as is the norm with NUT.
