KingC
Oct 11, 2020Aspirant
Apps not installing readynas 422 (rn422)
Hi to all,
I have recently factory reset my netgear readynas 422 (rn422) to upgrade it wiht 2x 12tb seagate ironwolf drives.
Before reset i was running 2x 6tb western digital reds.
Before the upgrade i had a lot of the apps installed python, plex, kernal, ssh to name a few. they all seemed to work fine and installed fine. I should note that they installed before the firmware update to v 6.10.3. And I installed them all from the apps menu on the UI.
After doing the upgrade of the disks and the factory reset. I now keep getting error messages, saying apps ca't install. I put the original drives back in, and I am still getting the error messages and obviously apps arent installing.
I have attached the error logs.
I can't believe this is happening as a unit it has been a great little investment. It hasn't missed a beat until now.
Can someone please point me in the right direction for a solution.
Any help will be greatly appreciated.
Kind Regards
- KingCAspirant
Sorry log file zip or install.log won't upload.
Please let me know what .Log file is required and I will covert to an uploadable .pdf.
Many Thanks.
You don't want to post the full log zip publicly anyway. If you want a full log file analysis, you send a downloadable link to the logs (google drive, dropbox, etc) to the mods using a private message.
Someone else is also seeing this problem though - look here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Problem-installing-applications/m-p/1990281#M43340
