slask
Oct 23, 2019Aspirant
Brokendown READYNAS 324 copy discs to new 424
Please Help!!!!! My ReadyNAS324 has broken down I have now invester in a new 424 and I need help to transfer files from discs i used in the old one to the new. I have understood that the discs wi...
slask
OK fine, but I'm not sure of the order of the discs
Oct 23, 2019Guru - Experienced User
You've already removed them?
Do you have a log zip file from the RN324? That will give you the serial number of the disks (sda being the first, sdb the second, ...).
If you don't have that either, you'll need to just put the disks in. The NAS will usually figure out the order. But in the future you should label the disks by slot as you remove them.
- slaskOct 23, 2019Aspirant
Now i have put the discs in the 424 and started it.
I get:
Err: Used disks Check RAIDar or Press Reset to format.
- StephenBOct 23, 2019Guru - Experienced User
I get:
What is RAIDar telling you? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- slaskOct 24, 2019Aspirant
It tells me that the discs are formated in an unknown way.
