aks's avatar
aks
Virtuoso
Jul 23, 2015
Can I have my old (3 letter) username back
My username on the ReadyNAS Forums was simply 'aks', but on the new forums it has changed to 'aks1', and in fact I can see that I also registered on developer.netgear.com (with a different email address - same domain), so maybe that's caused confusing.
How can I get both these accounts merged into one 'aks' named account?
  • Sure. I just renamed the aks user to aks2. That user only had one post so I think it's better for you to have the aks username.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    • dsm1212's avatar
      dsm1212
      Apprentice
      This seems to have been the default behavior for some reason. I have an extra 1 on my name too. Not that I really care, but maybe netgear should fix everyone.
      steve
        mdgm-ntgr
        This problem generally occurs when you have registered on multiple of the old boards using different email addresses.
        The user on forum1 gets the username in preference over the ReadyNAS forums user.
    • aks's avatar
      aks
      Virtuoso
      Thanks mgdm, the other account (now aks2) is also me with a different email address, which I will no longer use. You can delete that account if it matters in any way (and even move the other single post on to my preferred account, i.e. this one if that's possible).
ProSupport for Business
