Sp4
Dec 04, 2020Guide
Can I move the 4 disk RAID to another NAS??
Greetings, If the Ready NAS itself NOT the disk drives went bad. Would I be able to move the 4 disk RAID to another NAS and retain all my data? I hear the RAID is on the drives itself and I shoul...
- Dec 04, 2020
Hi Sp4,
In case the ReadyNAS chassis itself fails, you can move the disks to another 4-bay or more ReadyNAS OS6 units and it should retain all its data and config.
It will also be best if you have a backup of your data because the NAS alone is not enough to keep your data safe.
Dec 05, 2020Guru - Experienced User
Sp4 wrote:
If the Ready NAS itself NOT the disk drives went bad. Would I be able to move the 4 disk RAID to another NAS and retain all my data? I hear the RAID is on the drives itself and I should be able to, but I wanted to consult here in the forums for confirmation.
The OS is also on the drives btw.
You can migrate the disks to another )OS-6 ReadyNAS (preferrably an x86 model - RN300 and above).
- Sp4Dec 05, 2020Guide
Stephen,
Thank you for the extra info. Noted
