tigerten
Aug 04, 2023Luminary
Can Netgear update the firmware to reflect new changes?
I remember when I first bought a used duo years ago, only to realized most of the feature s on the web interface were long discontinued, but still showing up on the page. Netgear could have cleaned up...
tigerten
I don't remember ever announced the release of 6.10.9 as they they usually. It ws rolled out only after people complained about the 6.10.8 stopped working without official announcement. If you look at this page where people normally download all the needed softwares, it still showes 6.10.8 as the current:
https://kb.netgear.com/20684/ReadyNAS-Downloads
And if you try to update the firmware from 6.10.8, it tells you there is no new update.
Most people update their systems like this.
schumaku
Aug 04, 2023Guru - Experienced User
Not aware 6.10.8 stopped working ... probably some of the (mostly unsupported) Apps made it behave like that.
- tigertenAug 04, 2023LuminaryYes, 6.10.8 repo was damaged and they never fixed it. Instead, they quietly rolled out 6.10.9 without announcing it or made it available to auto-update. It is also hidden. It was one of the user who discovered it. It was never announced.
It should be made to allow audoupdat to access it.
https://community.netgear.com/t5/New-ReadyNAS-Users-General/Unable-to-install-apps-from-the-available-app-list-anymore-with/m-p/2311312#M51271 - StephenBAug 04, 2023Guru - Experienced User
As tigerten says, the Netgear repo for 6.10.8 has no essentially no accessible files in it.
A typical OS-6 Repo has about 1000 files and uses about 5.5 GiB of storage. 6.10.8 has only 34 files, and uses about 27 MiB. The problem is that the pool folder in the repo is missing (or perhaps inaccessible), and that is where all the packages reside.
The mods said they would look into it some months ago, but nothing was ever done.
Also, I discovered a couple of days ago that several of the apps on apps.readynas.com can no longer be downloaded. That includes Netgear-supplied apps (kernel plus and smb plus).
NiveditaP - is this something you can look into? Maybe also arrange to have 6.10.9 pushed on the normal update server???
