Yoda3647's avatar
Yoda3647
Can not connect
ReadyNas 316 Okay my problem started when my VPN tech Support told me to do this " Danil Kolesnikov (Support Team) Jan 13, 2022, 4:57 GMT+2 Dear Customer, Thanks for attached screenshot. ...
  • Yoda3647's avatar
    Yoda3647
    Jan 13, 2022
    Thanks for the quick reply but I figured it out. As to your question yes it was the Ready cloud app I was talking about, and as to the PING tried that and no response. Now as to the problem solving.
    I figured out that the VPN app from VPNunlimited automatically started when I restared my PC after reinstalling it and also the VPN app also has in the settings a KILL function that if the VPN is not on to not connect to internet, So I change the settings to not auto start and turned the KILL function off then I restared my PC and I can now connect to my NAS.
ProSupport for Business
