Sagar_Gurav
Oct 24, 2019Aspirant
Cannot save or edit in readynas 316
Hi, I have a ready nas 316 model, firmware 6.10.1. From few days i cannot save or edit files in the nas drive. If i try to edit or save in the nas drive its giving me an error saying "Microsoft Exc...
Oct 24, 2019Guru - Experienced User
Is "strict sync" enabled for the share?
- Sagar_GuravOct 24, 2019Aspirant
Hi StephenB ,
Thanks for the reply.
Yup it is enabled. So i will disable the "strict sync" option and check whether i can make changes to the drive files.
- SandsharkOct 25, 2019Sensei
Just for clarity, this happens only when you access directly via Excel, Word, etc. You can drag and drop a file to or from the NAS without any issues?
It would be helpful to know if the problem also occurs when you copy the file from the NAS to the PC desktop and then open it.
- StephenBOct 25, 2019Guru - Experienced User
Sagar_Gurav wrote:Facing the same issue after disabling the "strict sync".
Actually I was thinking you should enable strict sync.
