GregUnderwood
Nov 01, 2020Tutor
Cant delete Shares
HI, I cannot delete a share on readynas 104 s/w 6.10.3 - I get a configuration update failed error. any help is appreciated.
Sandshark
Nov 01, 2020Sensei
Are there any special characters in the share name? Is it set up to be accessible by any apps (PLEX, for example)? Have you ever made any changes to the share configuration (for any share) in SSH?
- StephenBNov 01, 2020Guru - Experienced User
Also, is the log page telling you that the root partition is full or that the data volume is read-only?
- GregUnderwoodNov 01, 2020Tutor
Hi
The Share has an underscore in it. I just tried to remove it and the and it comes up with an error:
Never SSH'ed to it
The NAS has ove 600GB availiable
All cloud services are off
Thanks
Have you downloaded the log zip file, and looked for errors in system.log and kernel.log?
- Mar 31, 2022Retired_Member
