GregUnderwood
Nov 01, 2020Tutor
Cant delete Shares
HI, I cannot delete a share on readynas 104 s/w 6.10.3 - I get a configuration update failed error. any help is appreciated.
GregUnderwood
Nov 01, 2020Tutor
Hi
The Share has an underscore in it. I just tried to remove it and the and it comes up with an error:
Never SSH'ed to it
The NAS has ove 600GB availiable
All cloud services are off
Thanks
Nov 01, 2020Guru - Experienced User
Have you downloaded the log zip file, and looked for errors in system.log and kernel.log?
- Mar 31, 2022Retired_Member
