Dewdman42
Aug 27, 2025Virtuoso
checksumming outside of raid?
I am just curious if anyone here is doing any supplemental checksum checking of their data beyond what btrfs does, for example to check the data before backing it up to an external source...or comparing checksums of the main volume vs backup volume, etc, etc, etc,
I know about md5sum....and there is an interesting utility called chkbit which can be setup to keep track of checksums for every file and uses the the timestamp to determine if the checksum needs to be updated, etc.. so it may be possible to run periodic scans to look for checksum mismatches, which might be bit rot or other glitch-caused data errors in the data. Generally I think this is not needed if the BTRFS raid1+ array has been kept healthy at all times, but I plan to use chkbit on my desktop computers to check for bit rot there and might put it on readynas also as an extra check to make sure the raid is not missing anything..and particularly I thinking I should put it on my backup volume which is not raided...and maybe compare the main raid volume against the backup volume or something of that nature...
Well just wondering what if anything others may have been doing in this regard.
after much reflection I have decided that using some kind of filesystem level checksumming is not a bad idea, but only on data that I don't expect to change. I will refer to that here as "archive" data. In which case a simple md5sum checksum saved somewhere will suffice for this purpose, can be created with bash script, should be created once per file and never changed (unless the file is actually updated). That way at any time I can check to see if the file is still as it was originally saved.
There are a variety of ways a file could be corrupted, besides just bit rot. Bit rot will theoretically be found and maybe corrected by btrfs. But other kinds of corruption from a variety of problems might end up as looking like perfectly legit file changes at the block level and would not be spotted. Which is where file system checksums come in. So if I keep these on my important "archive" data, and include it in all backups, at some point in the future I can always check the data and check my backups to see which are still good.
periodically checking them is not a bad idea to make sure its not corrupted and being backed up over the top of good backup. If I use snapshot versioning in the backup, then I can still get back to a good version too that way, and having the checksum will help me know.
so I see it as being useful, but only for "archive" data. Trying to track checksums of data that will be changed intentionally makes it very hard to distinguish between legit changes and corruption because it depends on file date and some forms of corruption would actually update the date. And or the date itself in meta data could also be compromised...so...I think it is quite complicated to keep updating checksums at filesystem level and not reliable anyway, so might as well forget it, just rely on BTRFS to do checksum checking at block level and then use checksums on "archive" data only. and no special tool needed, readynas as md5sum command which can be scripted in bash pretty easily to do that.
over and out on this topic.
FWIW, I use an old utility called winsfv to checksum my media files - one checksum file per folder. I was doing that before BTRFS, and just kept it up after I started using OS-6.
I don't verify the checksums regularly. But I do have them, just in case.
As far as backups go, I have enough of them that it is unlikely for bitrot to hit the same files on all of them.
- Dewdman42Virtuoso
- Dewdman42Virtuoso
Here's an interesting question, you may or may not to know the answer to. lets say I have a share and I'm making daily snapshots. then bit rot happens that somehow doesn't get corrected for whatever the reason.
Alright, so will the next snapshot pickup that bit rot change as a new delta on that file, despite the fact the timestamp has not been updated? I mean the file changed due to some corruption, but as far as the filesystem is concerned, the file hasn't been changed...so I'm asking what a new snapshot would do, seems like the last snapshot before the rot and the live version....would still both be the same..rotted..and if the file hasnt' been intentionally updated in a long time...I guess there wouldn't be any snapshot back in time with the non-corrupted value. Just thinking out loud, but wondering how btrfs determines there is a delta from the last snapshot. If it's by looking at the timestamp of the file....I guess it would think it hasn't changed. this is assuming scrubbing can't fix it....hypothetically, for right now now, let's assume non raid just to understand what snapshots do in that situation. Any ideas?
- Dewdman42Virtuoso
yea I remember winsfv, haven't used that in a long time.
Well the main thing is catching the bit rot before the corrupted data gets backed up all over the place. I guess I just like the idea of being alerted immediately if there is bit rot that wasn't corrected by btrfs scrub so that I can go find the last known good copy immediately and update at the primary source, or first try scrub maybe and then if still bad, go find the last known good version.
I like the idea of chkbit, I am still learning about it. It has many modes but one thing it automatically does when you scan with it, is check the current data against last known checksum unless the date has been updated, in which case it assumes you have intentionally updated the file and so it updates the checksum in that case. Then basically you can be alerted if the data has changed compared to the saved checksum, on a per file basis...and do something about it.
I could see running it before any backup, if it fails, then email me and don't do the backup. or if I have proper snapshotting on my backup dest, then it can do the backup but give me dates for when the checksum error is found and I can go recover the file from a snapshot.
In theory btrfs is doing this automatically during scrub. I'm actually more interested in checking my non raided files on my desktops that don't self-heal... And also scrub doesn't happen every day so there could be a window of time when the file got corrupted and backed up as corrupted...so I'd want to be alerted to go find the file from backup history and restore it healthy condition. My understanding is that in real world, this will not happen often.
Recently when I lost my raid5 array, none of the drives had failed, but it had been giving me bit rot detection errors and I wasn't sure what other make of that but the truth is, some data was compromised and wasn't self-healed, possibly because the drives were in the process of failing...and I never really had any way to go back and try to find out WHEN they got corrupted or try to restore from some backup snapshot somewhere a known corrupted file. Live and learn, I wasn't on top of the disk errors, but the bit corruption will be in the back of my mind now, not really knowing whether I can trust the data, hopefully most of it will work fine and it will only be by sheer luck that I stumble on the files that were bit rotted and maybe readynas didn't correct properly due to failing disks. Thus a chkbit report log before every daily backup would be useful I think if I really care about the data.
This would be useful, though I am thinking you could also monitor the BTRFS checksums. Though these checksums are on blocks, not files, so it would be tricky to trace back a BTRFS checksum error to a specific file.
Bit-rot can affect metadata, not just data, so depending on the date (or even the file name) isn't bulletproof.
