amazz20
Sep 10, 2019Guide
Chrome 77 Shows reset password
Currently running Chrome 77 on Win 7 going to the nas I get:
YeZ
Sep 13, 2019NETGEAR Expert
Have upgraded to v77 on a Windows PC and Mac OS computer, both worked right away, no issue.
Heard from a coworker that he had issue the very first time after upgrading to v77 that he was not able to access his NETGEAR router GUI, but it worked fine after rebooting the PC manually.
Can you two try to restart the PC once to see if Chrome v77 would then work with NAS GUI?
Sep 13, 2019Guru - Experienced User
It is working fine for me today (both with ReadyNAS and Orbi). As it happens, I did reboot after I posted the problem.
- YeZSep 13, 2019NETGEAR Expert
Thank you for confirming it works post a PC reboot once, not happening on every Chrome v77, but if it does, that is the solution.
- amazz20Sep 13, 2019Guide
Yep that worked.... Strange for Chrome to need a reboot, but it works.
- YeZSep 16, 2019NETGEAR Expert
Glad to hear that.
It seems like Chrome v77 has a glitch, we have tried earlier Preview version v78 that had issue too, but Google fixed it in later v78 release.
- amazz20Sep 16, 2019Guide
Thank you for the heads up on 78!
