Digital999
Jun 21, 2021Luminary
Configuration utility
Is there a utility or app that will enumerate the current configuration for a ReadyNAS system? In particular I am looking for RAM (size and type) and installed processor designation.
Jun 22, 2021Guru - Experienced User
You can get that info yourself with ssh, or you can download the full log zip file, and look in there.
What model NAS do you own?
- Digital999Jun 22, 2021Luminary
We have a mixture of 314, 424, and 626 units in multiple locations. Some may have been upgraded. It seems time to do an inventory census since complaints of slow performace are starting to be heard.
I was hoping that there would be a GUI utility instead of a command line interface with SSH.
Thanks again for resonding -- here is more info.
I certainly can use SSH to get the info. That said, we try and have the individuals responsible for the system at each site not be techies -- their job is to help make and sell wigidts.
That is why I was looking for a GUI based utility.
A complicating factor is the PuTTY logon -- I have found no effective way to paste the system password into the PuTTY logon window. Our passwords are in excess of 20 characters with many special characters -- essentially impossible to accurately type in for most mere mortals. Accordingly we will have to have a 'special' account allowed SSH access and turn it on/off each time we use it. Doable but not as good as I would have liked.
- StephenBJun 22, 2021Guru - Experienced User
Digital999 wrote:
...I was looking for a GUI based utility.
Netgear doesn't support CPU or even RAM upgrades, so they don't see any need to provide this in the web ui.
In the log zip file, mem_info.log gives you the amount of memory (but not the type). lscpu.log gives the processor. The amount of memory and the processor is also on the NAS datasheets.
FWIW, I've created my own script that creates the full log zip on each NAS, and then rsyncs it to the main one on a schedule. My need is a bit different from yours (my NAS are all on the same network) - but the backup NAS are on a power schedule, and this gives me logs w/o needing to wake them up and boot them.
