Forage
Sep 21, 2023Apprentice
Connect monitor to RN422
Before I open up my NAS for nothing: is there a way to connect a monitor to a RN422? Previous models has either some VGA or serial connector, but photo like https://community.netgear.com/t5/New-Ready...
- Sep 21, 2023
With the latest ReadyNAS, Netgear moved to the more common micro-USB serial connection, which is labeled "UART". See page 86 of the hardware manual: ReadyNAS_OS6_Desktop_HM_EN.pdf.
Forage
Or are those two black ports mini PCIe ports?
If yes, can I find at least one on the RN422 as well? And would it allow me to use something like :
https://icop-shop.com/product/minipcie-9160/
http://www.commell.com.tw/Product/Peripheral/PCI%20Express%20mini%20card/MPX-750.HTM
https://shop.dmp.com.tw/INT/products/87
https://www.innodisk.com/en/products/embedded-peripheral/display/empv-1202
Sandshark
Sep 21, 2023Sensei
- ForageSep 21, 2023Apprentice
Darn, I completely overlooked the label of that port, mistaking it for a regular micro-USB port. Many thanks.
Since there's no Netgear doc availble on the subject, to use the port: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-RN628X-stuck-booting-after-confirming-reboot-to-install/m-p/1743317/highlight/true#M179342
