eton
Apr 27, 2020Luminary
Create a new volume: Best practice?
Should quota be used? Create default shares does not create any shares on new volume. Why? Bug? https://i.imgur.com/eHH62vv.jpg
Marc_V
Apr 27, 2020NETGEAR Employee Retired
Here's a good KB on Quota https://kb.netgear.com/29891/ReadyNAS-OS-6-4-Share-quota
Are you saying there are no default shares (Documents, Music, Videos, Pictures) present after creating the volume? even when the option is checked?
- etonApr 27, 2020Luminary
1. Quota on volume?
I still don't understand why there is a quota setting on the volume.
The KB article describes quotas on shares.
Will quotas on shares only work if the volume has the quotas setting marked?
There is also no size limit on quota for volume, only for shares.
2. Default shares?
After recreating the volume for the 4:time the default shares appeared. I have no clue what's going on here. Just for the record: I haven't created any users yet.
- StephenBApr 27, 2020Guru - Experienced User
Space usage in BTRFS is a slippery concept, and turning on quota for the volume tells the file system to track it more accurately. So the setting has a non-intuitive name (unfortunately inherited from the BTRFS folks).
Even if you don't use quotas to limit disk space on any shares, it's helpful fo enable quota on the volume. Without it, you won't see the space used by snapshots or even the space used by each share. You can change it at any time, so if you can try it after you get data loaded onto the NAS. Just look at the shares page, and compare what you see when Quota on and off.
eton wrote:
2. Default shares?
Are you talking about Pictures, Documents, etc? Or are you talking about something else?
If you destroy and recreate a volume, the system won't recreate the default shares (Picture, Documents, etc). It will after a factory default. There's nothing special about those shares - you can delete the ones you don't care about, and create them manually when you recreate a volume.
