Teepoi
Sep 09, 2017Aspirant
Create Local storage
Hello There, We recently purchased the Netgear RN214. Did all the configuration and setup the Readynas Cloud using the desktop app. But unable to work along with it. Here is i want to do, let me kno...
Teepoi
Sep 15, 2017Aspirant
Thank you Sandshark,
The link https://ip.of.nas/admin says site cannot be reached.
Is there any step to step guide which i can follow the instructions or a video.
Kindly help
Sep 15, 2017Guru - Experienced User
Are you sure you are using the correct IP address for the NAS?
If so, did you try pinging it?
You can also download RAIDar - it can discover your NAS ip address, and it has a control to launch the admin interface.
