simonzee81
Jun 20, 2022Guide
Custom alerts when adding files to a folder
Hi All, I wanted to know if there is a way to send custom alerts to email adresses when adding/deleting files from a folder. Basically i want a notification to be sent to users using my nas wh...
Jun 21, 2022Guru - Experienced User
Basically i want a notification to be sent to users using my nas when a file is modified/added/deleted
The firmware doesn't provide this feature.
On OS-6 ReadyNAS there is a tool called inotifywatch that is installed on the NAS - you could try to write your own script using that tool. I don't know if that tool is installed (or can be installed) on 4.1, 4.2, or 5.3 systems.
- simonzee81Jun 21, 2022Guide
No worries 🙂
My Readynas Pro 6 Pioneer edition is running OS 6.10.7 😉
So i'll check the program you mentioned.
Thanks!- StephenBJun 21, 2022Guru - Experienced User
simonzee81 wrote:So i'll check the program you mentioned.
It's not something I've tried. There is a tutorial here that might help get you started: https://www.howtogeek.com/405468/how-to-perform-a-task-when-a-new-file-is-added-to-a-directory-in-linux/
Thanks, i'll look into this and get back with the results 😀
- Nov 30, 2019Retired_Member
