trneb
Jul 23, 2011Aspirant
D-LINK DIR-655
I have recently purchased a readNAS ultra 4 and set it up on the network... At first all seemed to be well, however I have not been able to get time machine backups to work well. When I first activate...
gilesrulz
Jul 28, 2011Aspirant
I don't have a full answer for you, but I have a DIR-825 and have the same problem.
At this point I have it pretty much narrowed down to a Bonjour problem, because when I mount the ReadyNAS share with command+k it will perform a time machine back-up as requested, but if that share is not mounted in that fashion, bonjour will fail to find it.
