trneb
Jul 23, 2011Aspirant
D-LINK DIR-655
I have recently purchased a readNAS ultra 4 and set it up on the network... At first all seemed to be well, however I have not been able to get time machine backups to work well. When I first activate...
trneb
Aug 01, 2011Aspirant
So update ... It seems it was a bonjour issue ... I found this thread: http://forums.dlink.com/index.php?action=printpage;topic=21069.0
To save reading ... if you go to 'advanced->advanced network' and then check the box for 'Enable Multicast Streams' everything seems to start working! I had to disable and then re-enable time machine on the readyNAS and now it shows up and so far I have not lost the connection! I can also see my afp shares along with my shared printer!
thanks for the pointers...
