jcontech
Sep 16, 2020Aspirant
Deflective RN212 - Help me save my drives!
My RN212 was causing sever network issues with all devices that were connected the same switch. All issues would be relieved once I removed the NAS from the switch. Eventually, I switched the network...
Marc_V
Sep 17, 2020NETGEAR Employee Retired
Welcome to the Community!
So using the 2nd NIC resolved the issue with your Network? Were you using a static IP address on the 1st NIC?
Regarding resetting or doing OS-reinstall on the NAS without the drives it is not possible, Do you mean when you reinserted the drives to the NAS that's when you lost access to your data? Can you still provide us any logs you have downloaded? Have you checked RAIDar utility to see what status is the NAS in right now? It might have been possible.
If the contents are lost, the worst case here is that the NAS performed a reset. If this is the case, the chances of recovering the data is slim to none. I hope this is not what happened so it would be best if you can check on the NAS thru RAIDar and see if you can gain access to it'[s admin page.
HTH
