jcontech
Sep 16, 2020Aspirant
Deflective RN212 - Help me save my drives!
My RN212 was causing sever network issues with all devices that were connected the same switch. All issues would be relieved once I removed the NAS from the switch. Eventually, I switched the network...
Sep 17, 2020Guru - Experienced User
jcontech wrote:
Eventually, I switched the network port from 1 - 2. I attempted to reload the OS & factory reset the NAS with my drives removed
To be clear on this - the factory reset is destructive and includes reformatting the disks. The OS reinstall doesn't destroy data.
Fortunately it can't be done with drives removed (and neither can the OS reinstall).
- jcontechSep 24, 2020Aspirant
I might have wiped my drives. The attached pic is what I can see now on the drive after reinstalling the OS. Can you confirm?
- SandsharkSep 24, 2020Sensei
It does not appear that you wiped the drive, but the volume isn't mounting, either. You are best off contacting Netgear support at this point.
