jcontech
Sep 16, 2020Aspirant
Deflective RN212 - Help me save my drives!
My RN212 was causing sever network issues with all devices that were connected the same switch. All issues would be relieved once I removed the NAS from the switch. Eventually, I switched the network...
Sep 17, 2020Guru - Experienced User
jcontech wrote:
Eventually, I switched the network port from 1 - 2. I attempted to reload the OS & factory reset the NAS with my drives removed
To be clear on this - the factory reset is destructive and includes reformatting the disks. The OS reinstall doesn't destroy data.
Fortunately it can't be done with drives removed (and neither can the OS reinstall).
jcontech
Sep 24, 2020Aspirant
I might have wiped my drives. The attached pic is what I can see now on the drive after reinstalling the OS. Can you confirm?
- SandsharkSep 24, 2020Sensei
It does not appear that you wiped the drive, but the volume isn't mounting, either. You are best off contacting Netgear support at this point.
