littomalt
Oct 08, 2019Aspirant
Delet a directory onNAS - SSH .AppleDB
Hi When I log in with putty ssh client i get this message: "Disconnected: No supported authentication methode avaliable (server sent: publickey)" I have enabled SSH with password authenticat...
Sandshark
Oct 08, 2019Sensei
Are you trying to log in as root (which is correct) or admin (which is not)?
littomalt
Oct 09, 2019Aspirant
Hi
I log in as admin, i will try root later today.
Is the password = admin password?
- StephenBOct 09, 2019Guru - Experienced User
Yes.
- littomaltOct 09, 2019Aspirant
With user: root, and pass = admin it worked
- littomaltOct 11, 2019Aspirant
I can now SSH to NAS 6.10.1, but the commands from: @johncove
This will delete all the Apple crud:-
find . -name "_*" -type f -delete
This will remove the Apple crud directories in question:-
rm -rd .AppleDB
dont seems to work.
I have not much experience in SSH commands, but can i get help to do the correct command to delte .AppleDB + recurring subfolders and files?
I run ReadyNAS OS6.10.1
And, is there a way to run the command to list possible deleted files without delte, a switch of some kinde like "/ListNotDelete"
Thanks up front!
