littomalt
Oct 08, 2019Aspirant
Delet a directory onNAS - SSH .AppleDB
Hi When I log in with putty ssh client i get this message: "Disconnected: No supported authentication methode avaliable (server sent: publickey)" I have enabled SSH with password authenticat...
littomalt
Oct 09, 2019Aspirant
Hi
I log in as admin, i will try root later today.
Is the password = admin password?
Oct 09, 2019Guru - Experienced User
Yes.
- littomaltOct 09, 2019Aspirant
With user: root, and pass = admin it worked
- littomaltOct 11, 2019Aspirant
I can now SSH to NAS 6.10.1, but the commands from: @johncove
This will delete all the Apple crud:-
find . -name "_*" -type f -delete
This will remove the Apple crud directories in question:-
rm -rd .AppleDB
dont seems to work.
I have not much experience in SSH commands, but can i get help to do the correct command to delte .AppleDB + recurring subfolders and files?
I run ReadyNAS OS6.10.1
And, is there a way to run the command to list possible deleted files without delte, a switch of some kinde like "/ListNotDelete"
Thanks up front!
- SandsharkOct 12, 2019Sensei
The find command listed without the -delete at the end will just list the files. I own no Apple products, nor do I know where you got that recommended command, so can't tell you anything about why it's not working, unless it's just not finding anything.
