Zecaf
Oct 13, 2019Guide
Deleted an account used for TimeMachine and my RN is now in ReadOnly Mode...
Hello all... New fun one: deleted an account in the WebUI (Firmware 6.10.1). I use accounts only to manage different TimeMachine backups. The Delete seems to be ok. Then my Mac pop an error probl...
Marc_V
Oct 16, 2019NETGEAR Employee Retired
Can you send me the full logs. There might be something else that caused the NAS to be on Read Only mode.
Regards
- ZecafOct 16, 2019Guide
Thanks for your answer. I sent you a private message with the link to the logs.
I hope you'll dig something useful. :)
- ZecafOct 17, 2019Guide
Still no idea?
I tried a scrub, nothing is fixed.
dmesg shows :
[ 105.003830] BTRFS error (device md127): parent transid verify failed on 718766080 wanted 271645 found 322138 [ 105.011617] BTRFS error (device md127): parent transid verify failed on 718766080 wanted 271645 found 322138 [ 105.011628] BTRFS warning (device md127): Skipping commit of aborted transaction. [ 105.011637] BTRFS: error (device md127) in cleanup_transaction:1864: errno=-5 IO failure [ 105.011641] BTRFS info (device md127): forced readonly [ 105.011645] BTRFS: error (device md127) in btrfs_drop_snapshot:9412: errno=-5 IO failure [ 105.011749] BTRFS info (device md127): delayed_refs has NO entry
And btrfs check --force /dev/md127
WARNING: filesystem mounted, continuing because of --force Checking filesystem on /dev/md127 UUID: 9d4171ad-fe40-45a0-9013-12e3db1a26fa checking extents checking free space cache checking fs roots checking csums checking root refs checking quota groups qgroup-verify.c:538: account_all_refs: BUG_ON `ref->num_bytes != num_bytes` triggered, value 1 btrfs[0x42ad55] btrfs[0x42ad74] btrfs[0x42ae39] btrfs(qgroup_verify_all+0x448)[0x42c0bb] btrfs(cmd_check+0x25c8)[0x44e842] btrfs(main+0x13d)[0x40c647] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7fd2ab413b45] btrfs[0x40c67b] Aborted (core dumped)
I had another error before my last reboot, related to qgroups too...
My last question if someone is still around: what is the safest way to start fresh? Factory default? I guess destroying the volume would not be enough to be sure all is back to "normal"? Thanks if you have informed inputs. :)
- StephenBOct 19, 2019Guru - Experienced User
I'd do the factory default - it doesn't take much longer, and gives you a fully clean OS partition.
- ZecafOct 20, 2019Guide
Yeah I did that and that was enough to kill another HD from 2015, 6 month after the warranty expired. Thanks Seagate (sector errors). I did an extanded drive check and ordered a new HD. Dusted the damn thing and the next time I have a problem, the whole thing hit the trash and I upgrade to a Syno. I'm tired of this. Really (and I've been defending ReadyNAS then Netgear for almost 20 years...). (To be clear, this is my 3rd major problem in less than 4 years with no support or remotly usefull help, and icing on the cake, this whole support forum framework is horrible, we're in 2019 and stuff like Discourse are FREE...) End of rant. Sorry. :x
