ialander
Aug 26, 2021Aspirant
Deleting large folders
Hi,
I have had replicate running since i started using the Readynas in 2016. It created daily backups of my production server.
I am starting to run out of space and need to remove some of the older backups.
Each replicate backup is a single day and seems to be several hundred GB. Clicking and deleting via the web GUI in the readynas takes half a day to delete one folder. Connecting via windows has the same behavior.
I cant delete the entire top level share as this is a production backup and I need the more recent files.
Is there a better way to delete these?
Thanks,
Do you have snapshots enabled on the share (hopefully not).
Are you using the web admin ui, or are you sharing the folder using https?
One thing you could look at is accessing the NAS with ssh, and using the linux command line.
- ialanderAspirant
Hi,
Snapshots are off.
I have tried using both the web gui and accessing via windows. The behavior is the same in both cases.
I have not tried SSH as SSH acess is not currently "on".
I think even with SSH i would have to go day by day vs. selecting a months worth of backups to remove at a time. can turn on SSH access and try removing each directory one by one that way to see if its any faster.
Thx.
Why are you thinking that?
Another option is to copy everything you want to keep into a new share and then delete the old one. Using cp -p -r --reflink will do the copy efficiently without taking more space (though you need to turn on snapshots in both shares temporarily to use --reflink).
