IanWilson
Jul 12, 2020Aspirant
Disc Errors reported - disparity between email alert, ReadyNAS Admin panel & logs
I have a ReadyNAS 426, which had 2x 4TB and 6xTB Seagate IronWolf NAS Drives. All drives have been checked as being ReadyNAS compatible. I recently added a new 8TB drive into my NAS, and during t...
IanWilson
Sorry - can't work out how to post multiple files - adding other screenshots & logs in reply posts.
- IanWilsonJul 12, 2020Aspirant
- Marc_VJul 12, 2020NETGEAR Employee Retired
It is always best to use the full logs downloaded when checking on the information, though the information being provided on the admin panel came from it as well but there are times that information or status has changed before it even came up atleast IMO, there are also items usually not indicated in a specific log file but might be present in the other or not just clearly presented so it's always best to get the logs for more information and clarification.
I would suggest replacing the said failing drive as soon as you have another one ready. If you have the drive out, it would be best to test it using Seagate's utility seatools to make sure that errors are found and you can request for RMA.
HTH
