IanWilson
Jul 12, 2020Aspirant
Disc Errors reported - disparity between email alert, ReadyNAS Admin panel & logs
I have a ReadyNAS 426, which had 2x 4TB and 6xTB Seagate IronWolf NAS Drives. All drives have been checked as being ReadyNAS compatible. I recently added a new 8TB drive into my NAS, and during t...
Jul 12, 2020Guru - Experienced User
IanWilson wrote:
So which do I believe - the logs, or the ReadyNAS email alerts and admin web panel???
Believe the email alerts. Your screen shots don't show the full smart stats. The easiest way to see them is to download the log zip file (from the logs page) and then look at disk_info.log
IanWilson wrote:
"Detected increasing reallocated sector count: [601] on disk 3 (Internal) [ST31000340NS 9QJ6T6CD] 11 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy."
I have contacted Seagate to see if they will swap out prior to a failure - or if I have to await the moment of "doom" !!
600 reallocated sectors and still rising says the drive has failed. You shouldn't use it in your NAS, no matter what Seagate says. Keep in mind that they have a conflict of interest, since replacing the drive costs them money.
But you'll find that you can RMA the drive (and I have done that with fewer reallocated sectors). If you test it with Seatools (requiring you to connect it to a Windows PC using a USB adapter/dock or SATA), you'll almost certainly find that it fails either the long generic test, or the full write-zeros test.
If you can't test it with Seatools, just use diagnostic code 659DC7AE when doing the RMA: https://www.seagate.com/staticfiles/support/seatools/seatools-test-codes.html
Seagate has never questioned RMAs I've done using that code (though I haven't needed it recently).
BTW, while Seatools will offer you an option to "repair" the bad sectors, I suggest skipping that. It will just attempt tor reallocate them (basically telling the drive not to use them). Your counts are continuing to rise, and in my experience the "repair" doesn't last. It's best just to replace it.
Seagate will give you a recertified drive, which will have a shorter warranty (typically 1 year). One option you should look into is doing an "advanced replacement". Then they ship you the replacement right away, and you ship them the bad drive after you get it. It's faster and more convenient - and their shipping charge is pretty reasonable. So if it's available in your geography, I suggest using it.
- IanWilsonJul 12, 2020Aspirant
Thanks for that - very helpful.
