NunovUrbizniz
May 03, 2019Tutor
do_exit+4b0
My RN104 has this error message on it [ do_exit+4b0 ]. Can someone please help
Marmor78
May 29, 2019Tutor
I got the same problem, my firmware is allways up to date so got the latest for the unit version 6.1.0.1,
when u power down the unit it power down harddrives and all like normal then power button is flaching and screen shows error do_exit+4b0 , onlyway to turn it fully of is to disconect power cable after the error comes up on screen , however the unit works perfectly when on and power up like it should so the error code most be specfic to shutdown only but its extreamly annoying
