khunter
Sep 25, 2018Aspirant
Download files from the ReadyNAS to another device
This is an older NG 3200. I need to download copies of the files from the ReadyNAS to our Data Domain unit. I can browse to the folder with the files, but when I try to copy the files, it does not gi...
Retired_Member
Sep 25, 2018Hi khunter, if it is possible to use your data domain unit as a backup target for your nas, try to go that way.
Good luck with fixing and kind regards
- khunterSep 25, 2018Aspirant
I inherited this unit and am not familiar with it. The files themselves are backup files. I am not sure how to backup the NG 3200. I can only browse to the folders with the files and folders. I am unable to map it to use it as a regular drive. I can upload files to it, but can't get them off without doing them one at a time. And that is extremely slow.
- StephenBSep 25, 2018Guru - Experienced User
The software manual is here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Business_SW_05Nov13.pdf
I suggest reading the section on backing up data on page 89. That describes how to create backup jobs on the NAS that will copy shares to a remote machine, using SMB, NFS, RSYNC, or FTP.
- SandsharkSep 25, 2018Sensei
Or at the very least, use the SMB or NFS protocols to access the NAS, not the GUI and HTTP(S). The backup job is the best bet, though, as you aren't relaying everything via a PC.
