luite
Mar 30, 2013Aspirant
Duo V2 out of memory prevention?
How familiar is it to you waking up finding your readinas responding to ping only - no https or ssh at all? You pull the plug :( for an unclean restart and after a restart you are good to go again. T...
chirpa
Apr 01, 2013Luminary
Your script is a good first step.
readynasd looks to have a lot of memleaks in it if I watch it over time.
If you are running backup jobs in the GUI that use 'cp' to copy files somewhere, like a CIFS backup job, there is a known memory leak issue there as well. The Remote install as of 5.3.7 is using an old coreutils with a cp that will eventually eat all memory and cause OOMs; viewtopic.php?p=371803#p371803
