Caesarea
May 03, 2017Guide
EDA500 connecting directly to PC
Before I order the EDA500 Expansion Chassis 5-Bay I want to verify if I can connect the EDA500 directly to my PC with Windows 10. Can anybody help me with this? Is there any compatibity list wit...
- May 13, 2017
The combination EDA500 and StarTech.com 2-port SATA 6 Gbit/s PCI Express eSATA (PEXESAT32) WORKS!!!
But if you connect the second EDA500 to the second port of the PCI, it does NOT work.
Good luck to you all.
Thanks for the responses!
Caesarea
May 05, 2017Guide
Totally, there are 6 bay which one has no SATA connection as you can see at one of the photos.
Then it is a 5-bay unit with a storage slot, isn't it?
I will try and post back/update...
- StephenBMay 05, 2017Guru - Experienced User
Caesarea wrote:
Then it is a 5-bay unit with a storage slot, isn't it?Yes - I've fixed my earlier post.
FWIW, there is a brief hardware overview here: https://www.youtube.com/watch?v=osAZODdTodo
