Caesarea
May 03, 2017Guide
EDA500 connecting directly to PC
Before I order the EDA500 Expansion Chassis 5-Bay I want to verify if I can connect the EDA500 directly to my PC with Windows 10. Can anybody help me with this? Is there any compatibity list wit...
- May 13, 2017
The combination EDA500 and StarTech.com 2-port SATA 6 Gbit/s PCI Express eSATA (PEXESAT32) WORKS!!!
But if you connect the second EDA500 to the second port of the PCI, it does NOT work.
Good luck to you all.
Thanks for the responses!
Caesarea
May 08, 2017Guide
I'm still waiting for the Startech® 2 Port PCI-Express eSATA Controller Adapter Card (PEXESATA2).
I also ordered the StarTech.com 2-poort SATA 6 Gbit/s PCI Express eSATA (PEXESAT32).
I will test both and share it with you all. Finger crossed!
Caesarea
May 13, 2017Guide
- SandsharkMay 13, 2017Sensei
Did you put in drives that already had data on them and find you could access that, or just empty ones?
- CaesareaMay 15, 2017Guide
Both with data and empty harddisk
- EmachineMay 13, 2017Aspirant
I have also a 2-port SATA 6 Gbit/s PCI Express eSATA. Here it doens't work, maybe on the card I need to change the jumpers or something else.
Can you acces all the 5 bays ?
Does your 2-port SATA 6 Gbit/s PCI Express eSATA supports port-multiplier?
What is the brand of this card?
- EmachineMay 15, 2017Aspirant
Concepttronic
PCI Express Card SATA 600 CSATA600EXI
So, you can acces all the bays from the EDA500 ? Can you let me know on what site you bought your card ? Maybe it's not allowedn here me e-mailadress
Where do you come from ? The Netherlands ;)
Thanks for your help
Luc
- doxdixenMay 19, 2017Aspirant
Hi Luc,
How are the noise levels with the expansion?
If you purchase the Startech 2-port it is just plug and play with the expansion?
Just put the HDD's in the expansion. Expansion connecting with eSata to the startech and you see your drives in Windows 10?
How are the speeds? If you write a big file to the HDD's what could you expect?
Regards,Jordi
p.s. also from the Netherlands ;)- EmachineMay 19, 2017Aspirant
HURRAY HURRAY HURRAY !!!!!!!!!!!!!!!!!!!!!
Probleem opgelost !!!!!!
Problem solved, it recognize now all my drive's !!!!!!!!!
The only thing you need is the right person !!!!!!!!!
Now all plug and play after I downloaded the JMicron JMB 36X Controller
Transferspeed very good, and I put the drive's in they comes right away available !!!!!!
Thanks all for the help
Luc xxx
