McRob2
Nov 08, 2016Aspirant
EDA500 Setup on RN516
I am looking for some instructions on setup for attaching a EDA500 to a RN516. I have reviewed all documentation and I cannot find any instructions on how to setup and configure a EDA500 external st...
- Nov 16, 2016
Thanks Stephen
That information does help, but it would be nice if there was actually published documentation that covers suggested configuration choices when installing a EDA500.
I guess the user is just supposed to know what to do when they purchase new equipment from Netgear.
I wonder if other hardware suppliers have better documentation of their hardware.
I would be completly lost without help from the netgear community.
Thanks for your help.
McRob2
Nov 09, 2016Aspirant
Thanks but I already read thru that data and I still did not find what I was looking for.
1. I see there are 3 eSata Ports on the back of my RN516 that are different colors. Which one should I plug the EDA500 into?
2. Are there any configuration changes I need to make in the RN516. I am currently running X-Raid (Raid 5) with (6) 6 TB drives?
3. How will the RN516 show the EDA500 hard drives. I plan on adding 5 drives that are 4 TB each into the EDA500. How should they be configred in the NR516?
I don't get my new EDA500 until next week.
Thanks for your reply.
sotrack
Nov 09, 2016Luminary
1. you can use any eSata port
2. No. Do nothing here.
3. You can choose any configuration on EDA500 volume (Raid-5, Raid-6, JBOD, xRaid,...). You will see additional volume in System -> Volumes page. For configuration eda500 volume (eda1 by default) you will do the same action like main unit volume
