john1in2
Oct 21, 2020Aspirant
Enable FTP on ReadNAS with TPLINK Router - Got it working
Well I have a ReadyNAS Duo and the expectation was I would be able to store and retreive data remotely. Hah! Its 2020 and this should be a lot easier than it is. First, ReadyCloud- this app is...
Sandshark
Oct 22, 2020Sensei
Another option, and the one I use, is a VPN. I use ZeroTier loaded on the NAS and my devices, though there are other solutions including ones that run in your router. This also supports remote backup without having to set up rsync over SSH, whihc ReadyCloud does not.
Oct 22, 2020Guru - Experienced User
Which is what I do as well (using the OpenVPN feature of my Orbi system). Then I can just use SMB as I would at home.
I supplement that with Resilio Sync running on an always-on PC at home that has the NAS volume mapped to a drive letter. I find that to be a convenient way to selectively transfer files to my mobile devices, and also to automatically back up my photos.
