mctubster
May 04, 2020Tutor
Expanded Raid 5 array. Snapshots and shares have all disappeared
Hi, I just added a forth 2TB disk to my existing 3x2TB Raid5 array. Resync went fine, have the new capacity, but at some point all of my snapshots and shares (except home for ones) have disappeared! R...
mctubster
May 05, 2020Tutor
I have a backup of the data that matters ... all of the data is still there, just the actual smb shares and snapshots are missing.
Are snapshot pruning events logged anywhere? I might have found the reason for all of the snapshots disappearing (ran completely out of space) as the resync was running (to be clear the resync didn't cause this, a large download ran unexpectedly), before the FS grew after the RAID5 expanded.
But can't for the life of me work out why the smb shares have gone missing.
Yes have SSH access etc.
Cheers
May 05, 2020Guru - Experienced User
mctubster wrote:Yes have SSH access etc.
Then first check that you have space on the OS partition. When it gets full, one symptom is that the NAS configuration files can get corrupted.
After that you can try running the script here.
- mctubsterMay 05, 2020Tutor
Hi,
Thanks a lot for that. The script rebuilt the share config files (I didn't realise they are stored on the /data volume in ._share ) which explains how they could be corrupted. OS partition never ran out of space. Also from the script output found out there are backups of these config files too!
Cheers
- SandsharkMay 06, 2020Sensei
For those to whom the script is not a foreign language, it explains a lot as to what is "under the hood" of the OS6 share system, how things can go wrong, and how they can be righted. I learned a lot from it.
